Air Conditioner Control Panel Lights & Reversing Lights
emmeci47
Hi.
I'm writing from Italy, where it is very difficult & expensive to find and buy spare parts for my car.
I've a 2004 Chrysler Grand Voyager 3.3 AWD with two electrical problems.
1. the air conditioning control panel switches don't light up;
2. the white reversing lights don’t light up too.
Where can I buy a second-hand control panel of the air conditioning system (or is it possible to replace only the burned bulbs)?
Do you know what controls the white reversing lights: a switch on the gearbox or an electronic board and where can I buy the spare part?
Thanks, Marco.
Ps: I bag your pardon for my English...
most dont light up
 if you take off the whole front grill
take out the two plugs /cover at top 2 screws and at bottom there a bit of trim in middle pull 2 screws there then pull the lot of the wooden side trims come with it
3 plugs pull color tab towards wire then pull plug out
unscrew the ac panel pries off back and and unclip pc board see if there is lights there if so test
the plug see if you got voltage when main light on
replace the bulbs
reversing light sorry dont know
