Stow N Go With Electric Driver Seat
Ringtail
So I've made the jump and just bought a 2008 Grand Voyager Executive XS and I'm loving it so far. I am however stumped by one thing, the drivers side seat is electric so I have the options to tilt the seat itself and the back rest but for the life of me I can't figure out how to adjust the distance of the seat from the peddles. There doesn't appear to be a bar to push in underneath like the passenger side and I can't find any automatic control for it. This basically means that I can't move it forward far enough to use the stow n go seat directly behind, so am I being a bit dense here or is there a simple solution?
Many thanks, In advance.
as above photo the long switch that tilts the seat also pushes forward and backward
and if you got on driver door a 1 S 2  button when you got radio set and seat and mirrors right with key on press S until it beeps then press 1 or 2 until beep and all will be pre program you can even set up each key for different people
