darkchild101 Posted September 15, 2014 Report Share Posted September 15, 2014 The blower on my Grand Voyager is very weak and on maximum i can barely feel the air on my face Any suggestions Quote Link to comment Share on other sites More sharing options...
0 Bash Posted September 18, 2014 Report Share Posted September 18, 2014 You will need a new resistor switch for your blower Quote Link to comment Share on other sites More sharing options...
0 macuniyanukukuk Posted July 25, 2015 Report Share Posted July 25, 2015 Could be the cabin filter blocked. Easy fix. Quote Link to comment Share on other sites More sharing options...
0 crispinchurch Posted July 26, 2015 Report Share Posted July 26, 2015 the filter is under the glove box a plastic cover slides to get it off and filter drops down the resistor is behind the glove open glove box and pull the rear sides of box inwards to drop box right down if fans are noisy but no puff on all setting then try filter first you dont say if you got full a/c or just 4 speed fans different resistor ebay £20 ish for full a/c one Quote Link to comment Share on other sites More sharing options...
0 darkchild101 Posted December 14, 2015 Author Report Share Posted December 14, 2015 the filter is under the glove box a plastic cover slides to get it off and filter drops down the resistor is behind the glove open glove box and pull the rear sides of box inwards to drop box right down if fans are noisy but no puff on all setting then try filter first you dont say if you got full a/c or just 4 speed fans different resistor ebay £20 ish for full a/c one It has an AC switch so i assume its got air conditioning (never worked) and then the big dial for controlling fan speed. So if filter is blocked is it simple case replacing it or cleaning Quote Link to comment Share on other sites More sharing options...
0 macuniyanukukuk Posted December 14, 2015 Report Share Posted December 14, 2015 Replace the cabin filter first Quote Link to comment Share on other sites More sharing options...
0 Sheen1 Posted January 18, 2016 Report Share Posted January 18, 2016 On mine i bought a new resistor from chrysler, failed after 9 months, got a free replacement which then failed after 4 months. Because tbe original was replaced, it was out of warranty. Chrysler suggested the fan was at fault. Got second hand blower fan £40 from chrysler breaker ACD, which sits under the passenger side of the dash, replaced fan and fitted new resistor. All working brilliant now. These cars are getting old and the maintenance upkeep is getting costlier. Thousands have been spent on my car. Quote Link to comment Share on other sites More sharing options...
darkchild101
Any suggestions
