Hi All
Grandy
Hi, I'm not sure on your Sebring but on a mini (with the same concept) that are located near the camshafts sprockets, you should see wires near there, is removed with a 10mm socket.
They look more or less like the one in the link below:
https://www.google.co.uk/search?q=sebring+vvt+oil+valve+location&prmd=isvn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjy1bj2wLHZAhXRWsAKHQHvA10Q_AUIESgB&biw=360&bih=560&dpr=2#imgrc=gDKXf0xLpKb-oM:
