2003 Chrysler Grand Voyager
dieseldog
Hello to all I was a member about two years ago but got my computer hacked so had to reinstall Windows.So here Iam again.Profession was HGV driver and fitter but now retired.Thats enough about me but I would be grateful for some help.Two years ago I bought a Grand Voyager 3.3,when I put it in for its mot it passed with flying colours,3 months later abs light came on checked with my Delphi it said left hand rear wheel sensor.I fitted a new sensor and the fault was still there left hand rear wheel sensor wiring fault.Checked the wires coming out of the sensor said 4-5 signal wire.Now the diagnosis is left hand rear wiring fault and left hand front wheel sensor fault ive also got an intermittent brake warning light coming after about 5 miles and stay on, if you stop the engine then start again it goes off for about another 5 miles.Can someone tell me where the sensor wires go first is it the ABS ECU The ABS unit sent of to be checked came back no faults.Thanks
Hi there and welcome!
Are the segmented rings in good condition? Mine corroded and threw up brake and abs faults. So I pulled the fuse for a while to get proper brakes back.
But my Mrs had also drowned the ABS unit by entertaining the kids driving through puddles.........
It dried out eventually.
