Fault Codes And More
mikebh8
Hi, I am using a program (some probably know it) and for those that don't know it I would like to share it with you.
All the files needed for the installation are in the folder attached to the below link.
On youtube you will find videos on how to install. Enjoy.
https://www.dropbox.com/sh/rbw862uakm1dhkl/AAAmsqoVtS7o7dFb8BH9xVWXa?dl=0
I am newish to dropbox sharing so if it doesn't work let me know and I'll fix it.
Attached is a snapshot with a list of what it should be in the folder.
@@andyb2000 remember I told you about more software, try this one.
Edited by mikebh8
Spot on Mike, handy that, good reference for a lot of faults and info. Just one downside, no P1 fault codes in there, but that's only a minor thing. I've already looked up sensors, testing and their guide ohm or voltage values, which is invaluable for testing sensors.
I found the getuid files missing, so grabbed them elsewhere and I've attached here just in case anyone else has problems.
getuid.zip
Welcome,
I'm not sure which files are usually deleted when the software is downloaded...I forgot to mention that the antivirus and firewall should be off otherwise will send some of the files into quarantine.
Every time a P1 code comes up it says manufacturer specification, I never looked into it, if I come across an updates I'll add them.
P.S. that is most up to date version of it, I used to use 3.38.
Enjoy
Voyager CRD IV gen wiring diagrams in that ver MikeBH ?
I managed to make a short video to show what the software is about.
It can be seen at the following link:
https://youtu.be/vSTSrzcjOVU
It is not the best quality as my usual screen capture software is down and I just downloaded a random one which is not great, future videos ( if needed) will be improved.
There was a problem with uploading it, no it's working.
Edited by mikebh8
