lme121 Posted January 1, 2018 Report Share Posted January 1, 2018 2003 chrysler voyager 2.5 CRD manual 1400000 miles This cut out on boxing day with no warning try restart and will not crank over also no glow plug light on upper dash and can not hear diesel pump Everything else works fine. Anyone had this problem can help thanks Graham Quote Link to comment Share on other sites More sharing options...
lme121 Posted January 1, 2018 Author Report Share Posted January 1, 2018 2003 chrysler voyager 2.5 CRD manual 1400000 miles This cut out on boxing day with no warning try restart and will not crank over also no glow plug light on upper dash and can not hear diesel pump Everything else works fine. Anyone had this problem can help thanks Graham Quote Link to comment Share on other sites More sharing options...
rhoygen Posted January 4, 2018 Report Share Posted January 4, 2018 Were you able to fix your problem? Quote Link to comment Share on other sites More sharing options...
lme121 Posted January 6, 2018 Author Report Share Posted January 6, 2018 Were you able to fix your problem?NO NOT FIXED DO YOU HAVE ANY IDEAS THE RED LIGHT ON STRERING DASH UNDER REVCOUNTER STAYS ON AND ENGINE WILL NOT CRANK THE FUEL PUMP ALSO NOT WORKING AND NO GLOW PLUG LIGHT REGARDS GRAHAM Quote Link to comment Share on other sites More sharing options...
bignev Posted January 6, 2018 Report Share Posted January 6, 2018 (edited) Oh bugger!The red light is the immobiliser circuit, I guess you have tried leaving the key in the ignition position for 20 to 30 seconds for it to recognise it? Do you have a spare key to try? Also try the proverbial "switching it off and on again" attempt, battery negative lead off for 20 minutes or more, rather than just the fuse out, then see if it accepts the transponder in the key this time? You may need the radio code after this. Oh and try posting this on the technical help section, most likely get the diesel drivers input too when it's spotted! Edited January 6, 2018 by bignev Quote Link to comment Share on other sites More sharing options...
