karmannski Posted December 13, 2017 Report Share Posted December 13, 2017 Hi Lads More problems for winter;( When I press brake to switch gear from P to D I hear Click (like a relay) Went back to P and every time I will touch the pedal it will click and ABS light will pop out. After I will switch to D, no clicks and ABS lights after 1-2 miles gone. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted December 13, 2017 Report Share Posted December 13, 2017 Hi there!Don't worry - Yep the click is correct, whether you've heard it or not, it's the release for the gear shift to come out of park.All 3 of mine have done it. The ABS light however isn't, but I don't know a related cause on that sorry. Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted December 14, 2017 Author Report Share Posted December 14, 2017 It never was so loud. It is not right. Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted December 29, 2017 Report Share Posted December 29, 2017 The click is normal, as bignev says it's the release for the auto gear shifter. To prove it, try and move the shifter without foot on brake, it won't move. If you put a little pressure on the shifter lever then put your foot on the brake you can 'feel' the release pin as it releases. For the ABS light, this is a self-resetting system (unlike engine management warning) so if it comes on and goes out then it's finding an intermittent fault on the system. ABS has quite a few components but basics first, is there enough fluid in the reservoir? Then I'd be suspecting wheel speed sensor/ring corrosion causing a 'bad' read of the wheel speed, that's most likely if it comes on/goes out whilst driving. If you don't have an SRS scanner to pull the codes (key dance is no good here) then take front wheels off one by one, check the wheel speed sensor (it's the black connector towards the top of the wheel arch that then loops down and has one bolt holding it against the hub where the teeth are). Then with a wire brush give the toothed speed ring a clean up. It uses magnetic inductance to generate a tiny A/C electrical voltage when it spins so it's very easily upset by corrosion and rust. Fingers crossed that might do it. I'd suspect it's not the sensors gone bad as you'd get the ABS light on constantly due to self-checks failing, etc. Good luck! Quote Link to comment Share on other sites More sharing options...
karmannski
Hi Lads
