Grand Voyager Working With Bluetooth
mikebh8
Hi, there has been discussions about if a bluetooth hands free kit would work on a grand voyager.
The link below is a video that I uploaded on youtube so I can show to whom it may concern that it works.
I have to mention that the amplifier hasn't been touched and the bluetooth sound will only work if the radio is on (at least this is the way I wired it)
Hi mike, thanks for that, can you list which SOT cable you used for it? I've found around 3 different SOT cables specified and they all don't work on my particular combination, hence my continued battles with it to make it work (I've actually bypassed the amp and rewired now as a solution).
The solution you put above DID work with my last GV (same thing, providing amp/radio is on, audio output worked from Parrot) which is what confuses me, they all appear the same year, etc but subtle model differences seem to have different wiring combinations for the audio systems.
My current exact model is 2005, CRD LTD XS AUTO 2.8L RG-body.
Hi Andy, if you remember in a discussion while back, I cut into the speakers' wires, I did it on a 3.3 from 99 few years ago same way as I couldn't find the right harness for it.
I can't explain why in other cases it can still be herd the radio as when Bluetooth is playing sound the radio should be on mute...
