Dido Posted November 22, 2017 Report Share Posted November 22, 2017 Any quick check for blockage or leakage.Or would it just be the pump replacement, how to access and where to source out???? Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted November 28, 2017 Report Share Posted November 28, 2017 On 11/28/2017 at 10:41 AM, Nello said: Here you go Dido - Mike takes the credit - http://www.chryslerforum.co.uk/topic/522-rear-washer/ As per the thread - squirt your washers with the bonnet open and you will see the hose shooting water out - it drops of from its connector by the battery......Glad I have my uses.... occasionally Nello 1 Quote Link to comment Share on other sites More sharing options...
0 Penguin2007 Posted November 23, 2017 Report Share Posted November 23, 2017 I am shooting in the dark here. but on past history .... ISTR that on the Brava / Bravo, there were two pumps located on the water fill bottle buried in the res of the engine compartment (looking into car. My Bravo, ended up with sludge in the front wash pipes, as a result of allowing the tank to drain fully, along with the accumulated crus from wash bottle additives. Suggestion: is the pump running to front windscreen? does the pump run when targeted at rear screen? if 2) - detach the water pipe and try again - runs - pipe blocked - more than probable - could switch pipes over, would switch front to rear - and try again.... You can then extract wash pipe from rear windscreen of car .... and blow out the crud - taking off the jet? If you take motor out of wash bottle - beware of the tidal wave of water - that will emirate from the bottle, and soak your feet! ISTR that the motors were a standard fit on tip / brava, could probably be the same, round about 20squid (years ago!) I doubt if there is is front back sender valve - but is too cold to go ferreting down at the moment , and its pouring with rain. A lot here on 'hope' and 'help' but I'm sure that it will possibly / more than likely be furring up of the pipes etc Hope this helps Penguin Quote Link to comment Share on other sites More sharing options...
0 Nello Posted November 23, 2017 Report Share Posted November 23, 2017 (edited) Check back within the forum Dido - Can you hear the pump but there's no fluid on the screen? Look under the bonnet and IIRC the hose tends to drop off from the pump - happened to me not long after I bought mine. I'll check and confirm where etc. Edited November 23, 2017 by Nello Dido 1 Quote Link to comment Share on other sites More sharing options...
0 Dido Posted November 27, 2017 Author Report Share Posted November 27, 2017 Thanks guys, I am gonna try these tips this weekend hope it works Quote Link to comment Share on other sites More sharing options...
0 Dido Posted November 27, 2017 Author Report Share Posted November 27, 2017 On 11/23/2017 at 9:19 PM, Nello said: Check back within the forum Dido - Can you hear the pump but there's no fluid on the screen? Look under the bonnet and IIRC the hose tends to drop off from the pump - happened to me not long after I bought mine. I'll check and confirm where etc. Yep, can hear the sound but no fluid comes offIIRC?? Quote Link to comment Share on other sites More sharing options...
0 Nello Posted November 28, 2017 Report Share Posted November 28, 2017 (edited) Here you go Dido - Mike takes the credit - http://www.chryslerforum.co.uk/topic/522-rear-washer/ As per the thread - squirt your washers with the bonnet open and you will see the hose shooting water out - it drops of from its connector by the battery...... Edited November 28, 2017 by Nello MikeyRules 1 Quote Link to comment Share on other sites More sharing options...
0 Dido Posted November 29, 2017 Author Report Share Posted November 29, 2017 (edited) That perfect guidance thanks mate Edited November 29, 2017 by Dido Nello 1 Quote Link to comment Share on other sites More sharing options...
0 Dido Posted December 11, 2017 Author Report Share Posted December 11, 2017 Managed to trace the washing fluid tank backwards. With a bit of squirt the connection tubing was dislocated.Reconnected, superglue and a metal collar and back to business. MikeyRules 1 Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted December 11, 2017 Report Share Posted December 11, 2017 On 12/11/2017 at 3:48 PM, Dido said: Managed to trace the washing fluid tank backwards. With a bit of squirt the connection tubing was dislocated.Reconnected, superglue and a metal collar and back to business.It's always nice when it's an easy fix... So was it at the pump end where it had come off then? Quote Link to comment Share on other sites More sharing options...
0 Dido Posted December 12, 2017 Author Report Share Posted December 12, 2017 Looks like that. Have a look yourself... ?The collar I had was a bit too big, do you think duct tape can provide good seal... Quote Link to comment Share on other sites More sharing options...
0 MikeyRules Posted December 12, 2017 Report Share Posted December 12, 2017 On 12/12/2017 at 2:10 AM, Dido said: Looks like that. Have a look yourself... ?The collar I had was a bit too big, do you think duct tape can provide good seal... Yeah looks familiar! I wouldn't use duct tape to be honest. You need some waterproof amalgamating tape that forms a seal like this: https://www.screwfix.com/p/self-amalgamating-rubber-tape-black-25mm-x-3m/2115V?tc=AT4&ds_rl=1249481&ds_rl=1245250&gclid=CjwKCAiAmb7RBRATEiwA7kS8VHHwSww2xiqOxWBkhf_Pmqs6cSJ0z2wBzGKAjEWPCZc7Cvp68OhhARoCyMUQAvD_BwE&gclsrc=aw.ds&dclid=CJDorvOXhNgCFRBuGwodAqQPbA Quote Link to comment Share on other sites More sharing options...
Dido
11 answers to this question
