CJE Posted October 28, 2017 Report Share Posted October 28, 2017 Hi, CV 2006 2.8crd, Drivers side Passenger door does NOT lock/unlock with Key Fob ? All other doors ok, Where to start ? ideas please Quote Link to comment Share on other sites More sharing options...
0 bignev Posted October 28, 2017 Report Share Posted October 28, 2017 Hi there,Presuming it won't work with any of the locking controls, the switch on the drivers door as well, then start with the central locking actuator in the offending sliding door, swap it for the other sliding door one to totally confirm, same motor but different arm. CJE 1 Quote Link to comment Share on other sites More sharing options...
0 bignev Posted October 28, 2017 Report Share Posted October 28, 2017 (edited) The bit you're looking for looks like this one: https://www.ebay.co.uk/itm/Rear-Sliding-Door-Door-Lock-Actuator-For-Chrysler-Voyager-Dodge-Grand-Caravan/182550266453?_trkparms=ao%3D1%26asc%3D20170912102017%26meid%3D93411373f2d64380a28e2f19b808edb9%26pid%3D100706%26rk%3D1%26rkt%3D1%26&_trksid=p2045573.c100706.m4781 Edited October 28, 2017 by bignev CJE 1 Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted October 30, 2017 Report Share Posted October 30, 2017 Yep mine had the same problem, got actuator same as in nevs link, cheap from China looks exactly the same as genuine. Only problem I had was the small screw access hole was missing in the door frame so I had to drill a new hole. Did the job 2 years ago and still worked CJE 1 Quote Link to comment Share on other sites More sharing options...
0 maxcaddy Posted December 16, 2018 Report Share Posted December 16, 2018 Not wishing to hijack your post , but this sounds exactly like what I have only that mine does work, but with a very loud buzzing sound from within the door. Anyway, the link to the new actuator is dead, but I see that there is this also on eBay https://www.ebay.co.uk/sch/i.html?_odkw=eBay+item+number%3A382283110528&_osacat=131090&_from=R40&_trksid=m570.l1313&_nkw=382283110528&_sacat=131090which seems to be the same. Any pointers on getting the Door Card off would be gratefully received. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted December 19, 2018 Report Share Posted December 19, 2018 (edited) Yes that's the actuator, and you must have cursed mine maxcaddy!! It's started doing that very loud buzzing when it locks!! But not when unlocking....So a new one is here for when I can get the time!! I can't remember accurately but there are a "few" Philips head screws, then the door card starts popping off (loudly) from the bottom, then lifts up over the door locking pin and window ledge and away. Quite probably there will be some Town & Country versions jobs on youtube of course. Edited December 19, 2018 by bignev maxcaddy 1 Quote Link to comment Share on other sites More sharing options...
0 bignev Posted January 2, 2019 Report Share Posted January 2, 2019 (edited) Hi guys!i got round to swapping the actuator today, while doing a couple of other bits like some exhaust repair paste on a hole in the middle silencer, hoping to get a bit longer out of it because as it's a stow n go I haven't yet found an aftermarket one (can find diesel ones). I can get a stainless steel one made & fitted fairly locally but am reluctant to spend money on the ungrateful sod of a machine.Put a new radiator on in the middle of November then the ignition coil goes one week later, at only 4 months old. I sent it back and got a refund no problem, just ruddy mither. New coil from the States in 2 days! Then changed the front drop links as one end of the nearside has gone, and noisy, significantly, after only 18 months. They were bought from Jeep Chrysler parts who are pretty good, so that was disappointing. But an easy job. So anyway I would guess you have done yours by now! Hey @@CJE ! Give a reply how it went?!But for others the removal of the door card is a Philips screw in the recessed handle / "ash tray" at the top of the door, pop off the surround for the rubber bumper, then start at the bottom and (loudly!) pop off the door card, raise it over the locking knob, release from the upper window surround and it's away.It has a heavy plastic sheet behind this, and a polystyrene block, presumably for a bit of noise insulation.A little torx screw to release the actuator from the door, slide forward a little, release the door knob rod from the clip on the actuator, remove the electrical connector and you're away.Refitting is not simply a reversal as you need to ensure the arc of the arm on the actuator is situated on the little barrel that is part of the door closer cinch motor, otherwise it won't disable this when "locked" and the opener button will operate. And it's hidden well, but isn't hugely difficult to feel for. The actuators are the same both sides, but the arm is handed. The ones I have bought came with both arms each time. Edited January 2, 2019 by bignev maxcaddy 1 Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted January 2, 2019 Report Share Posted January 2, 2019 (edited) I did the drop links about 20 months ago used aftermarket ones (moog I think) which seem to be lasting well Edited January 2, 2019 by Semmysonic Quote Link to comment Share on other sites More sharing options...
0 maxcaddy Posted January 31, 2019 Report Share Posted January 31, 2019 Well, had it been a bit warmer I would have changed the Actuator already, but as it's still working (other than the loud buzzing ), I've put that job off for a few weeks until it gets warmer, that is unless it gets a lot worse and starts to stop locking/unlocking . However, the text on how to take it apart was gratefully received. Quote Link to comment Share on other sites More sharing options...
0 Jerseyboy64 Posted November 30, 2023 Report Share Posted November 30, 2023 Hi all. Just purchased a 2006 Grand voyager ltd 2.8 any information appreciated, the rear tail gate is electric but once open closes on its own within seconds, I’ve read a few threads saying it’s the struts but the seller said it’s a sensor, the second problem is the l.h side door, it won’t unlock or open the button on top of the door is down and solid the right hand sliding door works but doesn’t lock any information appreciated as I don’t want to buy the wrong bits Quote Link to comment Share on other sites More sharing options...
CJE
9 answers to this question
