2.2 Pt Cruiser Will Not Start
keith9
Hi I stalled my cruiser coming out of my drive, went to restart but will not, it turns over OK got fuel at fuel filter and at the injectors (only loosened the pipe at top of the injector fuel there) can you help..
Auto electrician could not find any faults.
Keith
Hi, having fuel at the injectors does not mean much. If the pump doesn't send the right pressure it won't help. Do you have power to the injectors?
Did you start it with a different key than usual, it will start the car but eventually it will shut down due to lack of fuel delivery?
I'm not on my PC now to check values and such, but try google it for the right value.
It looks like immobiliser or auto shutdown relay which in a way are connected. Find the relay and swap them with something like fog relay or low beam relay, something not needed on start.
Edited by mikebh8
