Tailgate
Nello
Has anyone removed the inside panel of the Tailgate before? I've moved by p/plate on to my Delta which is only a 5-digit one and want to remove the the four lugs that are drilled in to the tailgate to hold the standard number plate on. Just wondered if anyone knew the process? Appears to be some bolts under the handles to close it?
Edited by Nello
...I guest you have to try spending some money in this case as it doesn't appear to be available free of charge.
http://vi.raptor.ebaydesc.com/ws/eBayISAPI.dll?ViewItemDescV4&item=202034260114&category=126726&pm=1&ds=0&t=1505974588507&cspheader=1
You might know the version if is a complete repair manual or a general overview of the car.
