Delta On A 12 Plate - Sat Nav Instruction Manual
Penguin2007
Hi
Slowly sorting out my problems .....
Is there a web reference for the standard factory fitted sat nag.
I spoke to Chrysler towers help line on friday, and the helpful comment was ''''speak to your dealer''''
Interesting reposte ....
I await your guiding answers through the conversion of post codes for holiday into lat / long co-ordinates.
Quite a performance - I may even resurrect my Garmin and use that if all else fails. Having to type in 16 characters, two decimal points and a (-) symbol because I am on the wrong side of the Greenwich meridian is far more complicated that postcode & house number.
What a p@@@ in the @@@e.
Regards
Hi
The unit is the original Chrysler / Lancia Delta factory unit
I have been referred to the following http://aftersales.fiat.com/elum ... etc ...
http://tinyurl.com/m7p6lcd
But this merely gives the electronic copies of the quick guides already supplied with the car.
The part number is 60395490 - costs £13.13 = $18?
This is on a back order to 'Jeep'
Navteq are uncontactable - original supplier of maps
Now home.com - again uncontactable - there is a web form, but, you have to be a business / have a www. to get the web form through
Has anyone got an electronic copy?
Or can someone give me the rudiments of loading in a sequenced KML file, via the USB? to plan a long journey, without having to dial in all the numbers individually.
Regards
Thanks for any help in advance
Chris
