3ddesign Posted September 18, 2017 Report Share Posted September 18, 2017 I'm sure this is well covered here but I've had to change the pipe from the ABS module to the front drivers wheel, because of a hole Do I have to bleed all four wheels or just this one ? Thanks Quote Link to comment Share on other sites More sharing options...
0 bignev Posted September 18, 2017 Report Share Posted September 18, 2017 Personally I would do them all, give it a treat and change that old fluid all through! Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted September 18, 2017 Report Share Posted September 18, 2017 Did you loose any of the fluid?...I assume so, as bignev suggested, the air in the system works in mysterious ways, I would bleed all of them.... Quote Link to comment Share on other sites More sharing options...
0 3ddesign Posted September 18, 2017 Author Report Share Posted September 18, 2017 Thanks, bled them all to be sure, bit of a faff getting at the back bleed nipples but done round the car twice to be sure. Quote Link to comment Share on other sites More sharing options...
3ddesign
