Voyager 2.8 2006
Tiggerqqq
Hi Everyone
is there anyone who can help me.
When driving in the voyager and I depress the brake 1st time its normal if I press it again almost immediately its stiffer if I then press it again it really hard any ideas ??
been told by local garage vac pipe is ok and have just changed servo at a cost of £470 but its still the same.
Any ideas please
Hi, do you get hot wheels( by touching them soon as you stopped), they should all be the same( be careful as if they are, it is very hot).
If by depressing the pedal there is no brake blocked (hot or noise coming from a wheel when driving) it is normal.
Try, while driving( on a dead end road with less traffic is ideal), pressing the pedal very slowly, release the pedal and after few meters push it down suddenly, if first is softish and second time is hard it works fine. As much as you push down the pedal harden it gets but if the system is fine it should come to initial state.
