eb9656 Posted August 11, 2017 Report Share Posted August 11, 2017 Hoping someone out there can help! I drove my voyager today no issues, parked up back at home went to use it 2 hours later & nothing, its as dead as a dodo. code flashes up p1130, need to find a garage asap as going on holiday next week. Does anyone know a suitable garage near Nuneaton?Here's hoping!!!! Quote Link to comment Share on other sites More sharing options...
mikebh8 Posted August 12, 2017 Report Share Posted August 12, 2017 (edited) Hi, you only asked for a mechanic in your area, I am far from there but still if I may how long you have the car for, did it start after charging the battery, or did it start at all after that?Do you have the dash lighting up, can you use any of the electrics? If you have power but not cracking, try inspecting the starter, an easy fix is bang it with the handle of a hammer(or a piece of wood), if after that gives signs that it crancks the starter needs fixed/replaced. If after charging or replacing the battery started, is that you left some electrics turned on and drained the battery...on this there is more to it, you might have a fault in wiring that does it, or depending on the model, it can be that when the key is removed from the ignition, is on ACC1 but in that case takes more than few hours to drain the battery. Moreover, if the alternator is faulty, you might have run the car on battery and now is flat. Add more symptoms and someone should be able to give you a diagnostic. Hope it helps. Edited August 12, 2017 by mikebh8 Quote Link to comment Share on other sites More sharing options...
mikebh8 Posted August 12, 2017 Report Share Posted August 12, 2017 Hoping someone out there can help! I drove my voyager today no issues, parked up back at home went to use it 2 hours later & nothing, its as dead as a dodo. code flashes up p1130, need to find a garage asap as going on holiday next week. Does anyone know a suitable garage near Nuneaton?Here's hoping!!!!Hi, I checked on my autodata version that I have, no P1 codes ( weird but there isn't any with starting with P1), but after googling I found the fallowing: http://p1130.ecufaultcode.com/ Please see the link above, and after finally having fixed the problem, please add it so the readers will have an idea for the future.Thank you. Hope it helps. Quote Link to comment Share on other sites More sharing options...
