Fayiz Posted August 1, 2017 Report Share Posted August 1, 2017 Hi I picked up my 2004 Grand Voyager today, it has the navigation system however needs the navigation disc. Does anyone know where the disc goes? Apparently there is a Navigation drive but I couldn't find it, does anyone know where it is? Thanks! Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted August 2, 2017 Report Share Posted August 2, 2017 Does yours come with the small display above the DVD/radio player?Above the display, within the same unit, there is a disc hole, that is for the satnav. Hope it helps. Quote Link to comment Share on other sites More sharing options...
0 Fayiz Posted August 2, 2017 Author Report Share Posted August 2, 2017 On 8/2/2017 at 7:55 AM, mikebh8 said: Does yours come with the small display above the DVD/radio player?Above the display, within the same unit, there is a disc hole, that is for the satnav. Hope it helps. I didn't quite get you, would a picture be possible please? thanks Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted August 2, 2017 Report Share Posted August 2, 2017 For some reason I can't upload pictures anymore, I can however copy/links. Is yours like the one bellow? https://www.google.co.uk/search?q=chrysler+grand+voyager+satnav&prmd=sivn&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjdg6uvtrnVAhUrBcAKHUWpAjsQ_AUIEigC&biw=360&bih=560&dpr=2#imgrc=1T6FC1mb1hretM: Unless is not the original, instead it has a newer version fitted on, could you post a picture of it? Quote Link to comment Share on other sites More sharing options...
0 Fayiz Posted August 3, 2017 Author Report Share Posted August 3, 2017 Yes, it's the original as shown in the picture you linked. Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted August 3, 2017 Report Share Posted August 3, 2017 I wouldn't bother the Sat nav system is so outdated, don't even think they have made an updated disc for years Quote Link to comment Share on other sites More sharing options...
0 Fayiz Posted August 3, 2017 Author Report Share Posted August 3, 2017 I ordered a 2017 cd, just wanted to know where it goes. Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted August 3, 2017 Report Share Posted August 3, 2017 On 8/3/2017 at 10:14 AM, Semmysonic said: I wouldn't bother the Sat nav system is so outdated, don't even think they have made an updated disc for yearsThere is actually an update for it...The only problem with the multifunctional systems, as one with Bluetooth/satnav/radio and other, when using the satnav it overrides the radio sound, or if an incoming call it turns off the satnav display( it's bad if it happens in a multi exit roundabout).I prefer have them separate and the original one as a backup. Quote Link to comment Share on other sites More sharing options...
Fayiz
Hi
Thanks!
