Bsymonds Posted July 31, 2017 Report Share Posted July 31, 2017 Hi, the service light has come on in my car (Delta 1.6 multi jet, 63 plate)Does anyone know how to clear this, as we have serviced the car ourselves in May.RegardsB Quote Link to comment Share on other sites More sharing options...
0 Rossocorsa Posted July 31, 2017 Report Share Posted July 31, 2017 You need multiecuscan software and then need to clear both service and oil degradation counters. If you are going to keep the car a while and do your own servicing and diagnostics is well worth buying as it will soon pay for itself. You need to run it on a laptop and get a set of connectors for the OBD2 socket. Andrewgrale and Bsymonds 2 Quote Link to comment Share on other sites More sharing options...
0 Andrewgrale Posted August 2, 2017 Report Share Posted August 2, 2017 You need multiecuscan software and then need to clear both service and oil degradation counters. If you are going to keep the car a while and do your own servicing and diagnostics is well worth buying as it will soon pay for itself. You need to run it on a laptop and get a set of connectors for the OBD2 socket.I use multiecuscan and it is a decent bit of kit I also have the old Fiat examiner system, but with license restrictions it's now out of date I have the Fiat/Lancia/Alfa tester too (the 1 with the cassette memories)Also have the PRO1 tester for the early generation of Fiat group cars, that weren't FLA tester compatible Quote Link to comment Share on other sites More sharing options...
Bsymonds
Regards
B
