After Market Double Dinn
david49west
After Putting up with the crap satnav and no Bluetooth
Ive fitted a parrot smart unit within the dash with a bit of cutting around the facia
I had to remove the amp in the back , and make some connections with the wires
coming to it from the front also fitted a high pass over for the 4 tweeters in the system
It all works fine BUT HERES THE ISSUE
the FM reception is low I've connected the aerial to the unit and checked the connections to the rear window
Is there any power amp within the aerial run , that was fed by a live wire from the old unit
any help on this matter would be good
cheers dave
Hi, check the link bellow.
Do you get power to the antenna, it should have 12v , I assume that it was getting power from the amp( not sure though).
https://www.google.co.uk/search?q=chrysler+grand+voyager+2001+radio+wiring+diagram&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjR2NCVirHVAhUKCsAKHYQbAKAQ_AUICigB&biw=1576&bih=926#imgrc=_
Hi, then the easiest way would be to fit a digital antenna.
http://www.halfords.com/technology/car-audio/stereo-fitting-accessories/autoleads-dab-film-antenna-smb-dab-aa1?cm_mmc=Google+PLA-_-Car+Audio-_-Stereo+Fitting+Accessories-_-338357&istCompanyId=b8708c57-7a02-4cf6-b2c0-dc36b54a327e&istItemId=apxtpxpa&istBid=tztw&_$ja=tsid:94971|cid:868555897|agid:49387676812|tid:pla-330242627417|crid:203456299599|nw:g|rnd:17043045887306992806|dvc:m|adp:1o6|loc:9045715&gclid=Cj0KCQjwh_bLBRDeARIsAH4ZYEP2e-6fMUpgbQPmu6Fe0wmDSpRhzm9rrm1ND3UW6ANgytDBoqoNDYAaAosTEALw_wcB
Or for further investigation, try disconnecting the radio and check if you still get power to the antenna, then disconnect the connections you made to bypass the amplifier (if you can do it one by one and check every time the power to the antenna is even better) and see if you still have power to it. In the bellow link you should see a picture with a radio c1 socket, pin number 5 is for antenna, is that connected to a pin(from the radio) that relates to "turning the antenna on". Plus make sure the wire is positive or negative.
http://www.tehnomagazin.com/Auto-radio-car-connector/CHRYSLER-Car-Radio-Wiring-Connector.htm
Take a look at the link bellow, it shows an antenna amplifier with short leads, so I assume it is near the radio enclosure.
http://m.ebay.ie/itm/Chrysler-Grand-Voyager-3-3-V6-PETROL-AUTO-01-07-AERIAL-ANTENNA-AMPLIFIER-/222521252306?nav=SEARCH
Also check this link too, try grounding the radio, from the radio case to the body),
http://www.lxforums.com/board/automotive-electronics-audio-and-video-/206743-poor-antenna-reception-aftermarket-stereo.html#post2802971
Edited by mikebh8
From the plug diagrams ( thank you ) its got the 22 pin what sends the signal to the amp
from the ebay link the amp must be in the rear panel at the top near the plug leads
prob then powered buy the amp
I can use the signal lead from the old circuit to run a live down from the aux live wire so wont flatten batt
cheers dave
