What Is Needed For A Cruisecontrol Install?
GVCamper
Hi, first you need the whole kit, which includes the harness, steering wheel controls, brake and accelerator sensors, cruise control module, it might be some more but I don't remember them now.
I quoted once for a different model, from scrap yards goes around £500.
You could go for a universal cruise control and with a bit of improvising you can add the controls to the steering wheels.
http://www.allfourx4.com.au/Cruise-Control-Kit-Auto-Pilot-Universal-12-volt-Aftermarket-AP60
As per the heated seats, look under the seats if the wiring is already there or behind the place where the buttons should be( if there is any plugs not used it could be the ones for the heating seats), if there is you need the seats, locate the fuse and find the buttons online. If there isn't you need to add to them a new circuit, if you have spare place in the fuse box use that otherwise use the rear window defrost fuse.
Hope it helps.
