Josboogz Posted July 23, 2017 Report Share Posted July 23, 2017 Hi All, Do any of you guys have any recommendations for coolant for the Delta. Paraflu Up seems so expensive and with 7ltr capacity would need 40 quids worth. I dont trust cheap brands just wondered what others have used. Thanks, Quote Link to comment Share on other sites More sharing options...
0 Andrewgrale Posted July 23, 2017 Report Share Posted July 23, 2017 40 quid is not a lot of investment for coolant which lasts 5 years (more in the real world), is guaranteed by a major motor manufacturer (FCA) and produced by a trusted source (Petronas) My Dad always told me that if you buy cheap then you pay twice, in order to rectify the situation when the cheap piece fails, assuming of course that the budget piece hasn't done consequential damages Oil and coolant/water are the 2 cheapest parts of your engine, but lack of either has the possibility to cause the most serious damage . . Do you really want to take the chance ??? My advice is to go with the proper, manufacturer approved fluid and top it up as you go along, with the same, rather than water Quote Link to comment Share on other sites More sharing options...
0 Nello Posted July 24, 2017 Report Share Posted July 24, 2017 Yep - what Andrew says............... Quote Link to comment Share on other sites More sharing options...
0 Josboogz Posted August 2, 2017 Author Report Share Posted August 2, 2017 Thanks for the advice. It is true buy cheap buy twice, normally something else fails and the coolant has to be replaced again. Fingers crossed this doesnt happen! Quote Link to comment Share on other sites More sharing options...
0 Andrewgrale Posted August 2, 2017 Report Share Posted August 2, 2017 Thanks for the advice. It is true buy cheap buy twice, normally something else fails and the coolant has to be replaced again. Fingers crossed this doesnt happen!I usually try to catch as much of the drained coolant as I can and use it as top up after the refil! Quote Link to comment Share on other sites More sharing options...
0 Dido Posted August 26, 2017 Report Share Posted August 26, 2017 Do you need to replace coolant even if it hasn't dropped level, mine is 11 registered been with me for 3 years now and never touched the coolant.!! Quote Link to comment Share on other sites More sharing options...
0 Nello Posted August 26, 2017 Report Share Posted August 26, 2017 The Service plan for both Diesel and Petrol cars includes a 'Check Coolant level' check every 2 years or 21k.........but does not specifically state when it should be changed. The only time I have ever had a complete flush / change of my entire coolant supply on any car is if I've had a need to have the whole system drained down for an issue (new Rad / Thermostat etc.)I do make sure though that the mix is correct every other year between coolant and water ready for winter - don't want anything freezing up! Quote Link to comment Share on other sites More sharing options...
0 Andrewgrale Posted August 26, 2017 Report Share Posted August 26, 2017 The Service plan for both Diesel and Petrol cars includes a 'Check Coolant level' check every 2 years or 21k.........but does not specifically state when it should be changed. The only time I have ever had a complete flush / change of my entire coolant supply on any car is if I've had a need to have the whole system drained down for an issue (new Rad / Thermostat etc.)I do make sure though that the mix is correct every other year between coolant and water ready for winter - don't want anything freezing up!The pink antifreeze is a 5 year lifespan The blue antifreeze is a 2 year lifespan Never the twain shall mix ! (Due to a chemical reaction)I usually top up with what I have drained at the last timing belt/water pump change Quote Link to comment Share on other sites More sharing options...
0 Dido Posted August 27, 2017 Report Share Posted August 27, 2017 ?That's very helpful thanks guys. Quote Link to comment Share on other sites More sharing options...
Josboogz
Hi All,
Thanks,
8 answers to this question
