Steering Angle Sensor Problems
casper171072
Had the car in the garage to find I have a problem with the steering angle sensor. They seem to be massivley expensive anyone know of an alternative.  I thought about one from the US  but would they not work with it being left hand drive and mine being an UK right hand drive.  Anyone know of a specialist where i might get a used one.
thanks in advance.
Hi, who told they won't work? the car ignition barrel is in the same place, I bet they will, try seeing pictures of them both.
Did you try taking it off see if is an easy fix...I never took one out from your model but sometimes is just a bit cracked pastic or a broken connection.
Also, before that, find some videos on how to reset it.
