Window Regulator Problem
Andrewgrale
Hi lads (and possibly lassies!)
My wifes 2012 Delta is giving a weird problem with the LHR window regulator
It started when my daughter knocked on the window, to salute a friend, as she put the window down
Since then the window will do anything but park in the closed position
It goes to the top and then right down again, if you inch it to the closed position it will stay closed, but if you use the remote to close it or use the automatic function it will close but then go straight back down again
It is only the lhr window
Ideas please!
I have an idea that it may be a motor problem, as I looked at the slides and all are clean and clear
12 answers to this question
Ah this is an easy one Andrew... The window needs resetting basically!
To reset lower the window and hold the button down for 10 seconds... count one and two and three to make sure you do 10 proper seconds. Then pull up and let the window go to the top holding it in the up position again for 10 seconds.
That should the reset them back to normal.
Good stuff!
This procedure also restores the one touch facility if that stops working too...
One last thing you may or may not be aware of is that you can put all 4 windows up or down using the key fob. Just hold down the unlock or lock button and hey presto! Particularly good if it's hot as you can open everything up and let a bit of fresh air in before you climb in!
  On 6/29/2017 at 8:34 AM, MikeyRules said:
Good stuff!
  On 6/29/2017 at 9:22 AM, Andrewgrale said:
Dunno what I did there, but yeah I am aware of this feature, which is a great idea!
It's also fitted to most of the FCA group cars, except, strangely enough, the new Tipo :-O
Then again, it's built on a price and I'm sure that nothing comes for nothing
Yeah I've owned most of them!! :P
Punto's don't have it either which is strange as they're usually really well spec'd. Haven't tried the misses Mito yet...
It's on the Punto lounge (I think it is called the GBK over yonder) the 1 with the 4 electric windows
Ah that makes sense... I sell a few Punto's mainly 3 door 'Easy' spec as they pretty much have every conceivable extra, but oddly not that feature!
