bazzer Posted June 16, 2017 Report Share Posted June 16, 2017 (edited) Hi and good evening to one and all,Grand Voyager Owner here,My Name is Barry or "Baz" if you wish,I have a problem with the leak off pipe from numbers the1 - 2 not staying on, I have replaced the connectors on the 2 injectors after snapping them. (Long story) I have also replaced the woven fuel pipe, is the diameter of the pipe tiny?can anyone help me thanks,Barry. I can't see how or where the fuel goes from the leak off pipes? also if I try to keep the pipes pressed on the engine starts to act like it is only running on 3 cylinders? "help" Edited June 17, 2017 by bazzer Quote Link to comment Share on other sites More sharing options...
