tazz316 Posted May 21, 2017 Report Share Posted May 21, 2017 pt cruiser 51 plate limited edition 2.0l petrol 5 speed manual 68000 miles no mot on sorn so will need to be trailored away i have owned the car for 12 months ..car was not running when i got it... it had a head gasket problem replaced head gasket reconditioned the head new timing belt and tensioner new water pumpnew spark plugsalso replaced cam censorcrank censorthrottle censoridle censormap censorreplaced cooling fannew clutch fittednew middle box and rear silencernew chrome 17" wheels with mint tyres... tyre size is 205x50x17new trackrod endsnew wishbone suspension armsnew batteryreplaced throttle bodynew bootlid handlenew bootlid strutsall the chrome on the car i boughtalso has haynes manual BAD POINTSthe car runs and idles ok but when you take your foot off the throttle engine dies car also over fuels when started up been told the censors need coding there is also a power drain on the car i think its the ignition barrel there is a key release button on the ignition but sometime the key can be taken out without pushin the button hence leaving the ignition on the first clicki have a full replacement lock set for the car with two keys as the present key does not lock or unlock the doors and boot only works the ignition and fuelcapbodywork is in good condition age related marks nothing majorhave full v5 document also other paperwork to go with the cari have spent quite a few quid on this car to try and get it right but time to throw in the towelwould be perfect for enthusiast as alot of stuff has been replaced there is also a roof spoiler to go with the car it will need respraying probably an easy fix for someone who knows these cars the starting bid nowhere near reflects the amount of money i have spent on the car a bargain for someone viewing welcome .....i thinks thats about it.... if i remember anything else i will update listing£495.00 Quote Link to comment Share on other sites More sharing options...
