Need To Rev Car To Get It To Move Then It Runs Fine Any Advice
hotrod1958
Had problem with car revs fluctuating fitted new accelerator pedal changed oil and filter in gearbox now I have to rev car to get it to pull away then it runs perfect changes gear smoothly kick down works as it should should I do another oil change in gearbox or anyone any advice please
Hi, don't get it for granted but to me it sounds the clutch...
When moving from stop the clutch needs to operate at its full potential, when the car is moving already even a quarter of it would do.
Is yours automatic or manual?
I am no expert and I know little about gear boxes but on automatic gearboxes the clutch is a component like "torque converter system"  which includes more parts and that all together connects the engine with the transmission.
On manual ones it could be the clutch master and/or slave cylinder ( it comes as a set) that does not allow the bearing to fully depress.
Hope it helped.
