karmannski Posted May 14, 2017 Report Share Posted May 14, 2017 Hi all! I'm looking for the correct radio adapter for GV 2006 CRD. I want to upgrade my stereo so I can play MP3/USB there is many on the market but they are all different harnesses. Quote Link to comment Share on other sites More sharing options...
0 bignev Posted May 14, 2017 Report Share Posted May 14, 2017 Hi there! Only a suggestion - don't do it - heading for major headache and heartache, they are a nightmare because of the amplifier and speaker system. If you have the AV plugs on the front of the DVD player I would suggest a lead adapter to this. I know some of our other guys will chip in now, and plenty of them are better than me on some of this stuff! They have more time and perseverance than I do nowadays. Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted May 14, 2017 Author Report Share Posted May 14, 2017 Ok. Cool , thanks for that info bro Yes i do have DVD , soni just need adapter for tnę AV ? Quote Link to comment Share on other sites More sharing options...
0 Semmysonic Posted May 14, 2017 Report Share Posted May 14, 2017 Yes you can, I run a cheap media player through the av sockets, run power from cig lighter, works a treat, plays films off USB also slot for sd card. Off the top of my head it only cost 15 squid. I have posted oh here about it before but can't find the post at the moment. Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted May 14, 2017 Author Report Share Posted May 14, 2017 Thanks guys! Quote Link to comment Share on other sites More sharing options...
0 GVCamper Posted May 21, 2017 Report Share Posted May 21, 2017 I did this in my 05 with no hassle, if you dont have the infinity system originally there is no external amplifiers. Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted May 21, 2017 Author Report Share Posted May 21, 2017 Infinity? How can I tell? Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted May 24, 2017 Report Share Posted May 24, 2017 (edited) And here's the word of caution! There are several different versions (Infinity is just one option. In some cases infinity have the infinity label on the speaker grill, but I've also seen them without that label) and I've so far come across three different systems in total now in these, all in the same year/build (2004/2005).I've not played with the 2006 one yet, but assuming similar (They did change a few things from 04/05 to 06) then the radio will be pumping out a digital signal on the 4 outputs (front left, right, rear left, rear right). That digital signal is then either fed to the amp or to the doors and then converted to analogue signal (sort of!) for the speakers to reproduce. This is the bit I need to investigate further, what does the digital to analogue conversion. My assumption is this is the amplifier on my model. So in a nutshell, use what you have like the others say, if you already have aux inputs, use them (Though if it's on the DVD player you might find audio will only come out the rear speakers or infra-red headphones and not the front if it's the full split system installed).Otherwise, like me, you've got a bit of work involved in finding out what you have and how to tap into it without very expensive modules to tap into the Chrysler can-bus system. I'm planning on taking my rear interior quarter apart and finding the amp and doing a *very* detailed dig of what I can discover on my current model later in the year as I want to upgrade my head unit to an android all-singing/dancing unit and will need to do the legwork to make it work! Edited May 24, 2017 by andyb2000 Quote Link to comment Share on other sites More sharing options...
0 bignev Posted May 24, 2017 Report Share Posted May 24, 2017 Hi guys, When I tried my Mrs ipod in the AV inputs it played video to the overhead screen and sound all round! Sorry for the mini hijack but how is your engine doing @@andyb2000 ? Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted May 25, 2017 Report Share Posted May 25, 2017 Ah good thinking @@bignev I'm gonna give the aux inputs a go, I was basing that on my last GV which did the above. On the engine, all good and back on the road. It was a cracked flexplate in the end, so separated the autobox from the engine (bellhousing bolts, flexplate bolts removed from the starter motor hole when removed), got enough space to get the flexplate out and replaced. Cost from dealer was around £80 for the new flexplate.I've been planning on doing a full write-up on steps and gotchas doing it when I get round to it! All up and running and happy again though, cheers for asking m8 :-) bignev and QinteQ 2 Quote Link to comment Share on other sites More sharing options...
0 bignev Posted May 25, 2017 Report Share Posted May 25, 2017 That's great news mate! andyb2000 1 Quote Link to comment Share on other sites More sharing options...
0 karmannski Posted May 28, 2017 Author Report Share Posted May 28, 2017 I will stock to the bignev advice and use AV / media player Quote Link to comment Share on other sites More sharing options...
0 bignev Posted May 28, 2017 Report Share Posted May 28, 2017 I bought the ipod / phone to AV lead from ebay, £1.29!!!!!! And it works - so far hey! Yes, including an envelope and delivery! Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted June 9, 2017 Report Share Posted June 9, 2017 I use Spotify a lot for my music (my iPhone) and I bought the AV adapter but as andyb2000 said I only get sound in the rear of the adapter is fully pushed in. I wiggled it out a bit though and sound does come in the front speakers to, but it's obviously very temperamental! Any suggestions on how I can make it a better connection please? Thank you! :-) Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted June 12, 2017 Report Share Posted June 12, 2017 (edited) I suggest trying a different AV adaptor and if you have the same output, replace the socket as it might be widened from previous use.Hope it helps. Edited June 12, 2017 by mikebh8 Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted September 22, 2017 Report Share Posted September 22, 2017 Thank you @@mikebh8 I'll try that. Sorry for the delay in getting back! Been a bit preoccupied! Mrs is now the actual Mrs, now I can get back to my beloved GV again! :-p Quote Link to comment Share on other sites More sharing options...
0 bignev Posted September 22, 2017 Report Share Posted September 22, 2017 Hey - Congratulations there!!!! robbie2red 1 Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted September 23, 2017 Report Share Posted September 23, 2017 Welcome to the club....Good luck. Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted September 23, 2017 Report Share Posted September 23, 2017 Thank you @@bignev and @@mikebh8 it just means she gets to boss me around officially now! ;-) bignev and DaveHoughton 2 Quote Link to comment Share on other sites More sharing options...
karmannski
Hi all!
18 answers to this question
