I am trying to remove the rear discs on my 2001 Grand Voyager. Another driver in our household kept forgetting that the Voyager doesn't have an electric parking brake and it has been driven with the brakes on frequently and now needs new brake shoes. I have got all new parts to go back on, discs, pads, shoes, springs, slides, adjusters, pistons, seals...
I have removed both calipers for rebuilding but I can't get the discs off the hubs. The clips on the studs must have been discarded when a previous owner had the brakes done.
The discs rotate freely by hand. They probably have very little lining left on the shoes inside and I have pushed the cable levers rearward to create some more slack for which there is quite a bit of travel on the levers.
I have tried to wind in the adjusters but I can't see them or tell if they are actually rotating when pushed upwards with a screwdriver.
The disks are stuck solid. I have tried penetrating oil, hammering and heat from a blow torch which is something that I don't like doing near bearings but I'm getting desperate now. I am going to hire a three leg puller with an eleven inch span tomorrow but other than trying that I don't know what else to try that is non-destructive.
I have thought about cutting five radial slots, one from each of one side of a stud deep into the hat but not through it but all the way through the disc surface. With five segments clearly cut, driving a cold chisel wedge between them may fracture the disc enough to get a chisel between the hub face and the rotor hat to separate them.
vvv
