poopydog Posted April 20, 2017 Report Share Posted April 20, 2017 Hi all.Small amount of coolant leakage approx .25 litre every 2 monthes.Leakage identified in two places, waterpump/ possible cor plug in block by water pump thermosat. Ideas please?cost of each item if unsalvagable and from where? Difficlty? ie home or garage? potential damage if left to fail? Quote Link to comment Share on other sites More sharing options...
Penguin2007 Posted May 7, 2017 Report Share Posted May 7, 2017 (edited) Mileage?Age - registration date? My 33k mile has just undergone a full water pump, cam and watts a face replacement. Ablate a little more expensive than doing it at home, I am not a mechanic wielding spanner man, - its a necessary 5 year / 48 000 mile event. The seals in water pump /pipes et al could have worn through - vibrations can cause micro tears in any material.Far cheaper than replacing the engine and the inconvenience of the day in the 'clinic'. Water pump goes = damaged engineCam failure = damaged catastrophic engine Errr lots of wonga! Penguin Edited May 7, 2017 by Penguin2007 Quote Link to comment Share on other sites More sharing options...
