2.8 Diesel Cutting Out.
Dizzy
Hi, i'm Dizzy & getting Dizzier. Could anyone out there answer or guide me to a solution to;
accelerate the Voyager & the engine cuts, will start up no problem. When driven easily/slowly it runs all day.
If you want to overtake it cuts, doesn't splutter, cough just stops.
It has had ;. new filter & primer head (some time back) pressure reg on fuel rail.
I believe this problem is electrical because it cuts out, dosen't die.
New input/output switches on G/box, changed throttle pedal. NO manual for this, no autodata wiring diagram. No-one seems to have any diagnostic equipment to reed this. Also no fault codes that I can see.
I think its heading for the snap heap,  LX CRD 2005.
Can someone give me relief?  thanks Dizzy.
I'd be looking at the fuel filter still.
Remove it, pour the contents into a container and see if there's any crud in it. Check there's only 1 o-ring in there too, just in case. I'd be tempted just to change the filter again, and make sure it's tight.
With my current Voyager, the seller serviced it before I picked it up. It cut out a couple of times, and I ended up having to get it recovered. They had changed the fuel filter, but had only put it on finger tight. It was drawing air and causing the cutting out.
  • 3 weeks later...
Hi folks, thought I'd let you know that the fault on the Voyager has been fixed. As I said the engine would just cut out if you revved above 2,500 rpm.
We managed to find someone with the correct diagnostic equipment. Thanks for the info on the site for this info.
In the short of it, we decided to replace the diesel fuel injectors (service exchange) . Re-seat & clean, new units fitted.
Run up check for leaks etc then road test. This has returned the G V to its proper behaviour.
On discussion with the tech that provided the diagnostic, he has had similar problems, even when the injectors are removed & tested they still passed checks, refitted the problem was still present. He believes that the fault sometimes is heat related ?.
Hope this info helps you fellow G V owners.
          DIZZY
