hotrod1958 Posted March 25, 2017 Report Share Posted March 25, 2017 Getting me down now rev fluctuate in drive ok in reverse and 3 had it on diagnostics no codes showing or engine management light on any help please getting desperate now Quote Link to comment Share on other sites More sharing options...
0 ametcalfe1989 Posted March 25, 2017 Report Share Posted March 25, 2017 Might seem a little odd but it could be your apps? Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted March 25, 2017 Report Share Posted March 25, 2017 Is it the same car as previous posted? You topped up the oil...It didn't come back to life?Try removing the bottom bolt, from the gearbox, make sure you have a container for the oil that will come out. It is magnetic, if you have metal residue on it it means the fault is in the gearbox itself due to lack of oil. Quote Link to comment Share on other sites More sharing options...
0 hotrod1958 Posted March 26, 2017 Author Report Share Posted March 26, 2017 yes its same car mike ive bought a delphi reader and software not showing any codes runs in reverse and 3 its just in drive revs fluctuate between 1500rpm and 2000 rpm as thjough gearbox is in limp mode will have to remove sump on gearbox Quote Link to comment Share on other sites More sharing options...
0 hotrod1958 Posted March 26, 2017 Author Report Share Posted March 26, 2017 Might seem a little odd but it could be your apps? what apps Quote Link to comment Share on other sites More sharing options...
0 mikebh8 Posted March 27, 2017 Report Share Posted March 27, 2017 I don't know if applies to this model too but on a Mercedes c220 was the battery that was sending wrong signals to the electronic gear shifting module....Try see if it works one yours.Hope it helps. Quote Link to comment Share on other sites More sharing options...
0 ametcalfe1989 Posted March 27, 2017 Report Share Posted March 27, 2017 Sorry didn't make that very clear, accelerated pedal position sensor. I had similar symptoms and thought it was the gearbox but it was ended up being a corroded connection in the APPS plug Quote Link to comment Share on other sites More sharing options...
0 ametcalfe1989 Posted March 27, 2017 Report Share Posted March 27, 2017 Accelerator* Quote Link to comment Share on other sites More sharing options...
hotrod1958
