Engine Cover
bigfrank
7 answers to this question
well i think i blew my horn a bit quickly
parcel arrived but turned at to be 6 post instead of 6 rubber crommets ,,,,,,,,,,,,,,,,,,,,,,,,,,,duhhhhhhh
called supplier and was then informed no grommets available the engine cover has been modified and i would need to order a new one but the new post's that
i all ready have would be needed ,,,,,,,,,,,,,,,,,,,,,,,,,
i asked so how much is a new engine cover then ????????????? £ 156 plus vat so i replied they could stick it and keep it as i'm shure i can make or get somthing else that will do the job
so in the mean time ill drive around with a rettling loose engine cover
I wouldn't let it rattle around for too long.  I've got the same issue and the loose cover has started to 'burn' through air intake rubber hose/pipe and electrical wiring.  It's even melted a couple of ridges into the top of the engine block!  Pretty tough engine cover.
Has anyone had any luck tracking down replacement rubber mounts that bigfrank was looking for?
Sorry, old topic I know, but I have an answer for the question.
After a bit of googling, I managed to find replacements for my 2011 Voyager engine cover. Take one of the originals to a Mercedes garage, they are also used on Merc vans as it’s the same engine. I took them to Chrysler in Norwich and they quoted me a new cover.....typical. Walked across the road and problem solved!
£11 or so later I had 5 new attachments for my cover, and is now solid.
Steve
