Side Indicator Dead
GVCamper
Update: metered the wires and got zero voltage.
The blinking pace is regular even though a bulb is missing.
I'm thinking the BCM might be my problem since i also get codes on the central locking and sometimes it doesnt work until i pull the BCM fuse to reset it.
If anyone got ideas i'm very thankful as I need to pass MOT
When you say metered the wires, have you removed the bulb holder and had the meter directly on the wires at a plug coupler? If not, i'd be looking at the bulb holder, or trace it back to a plug connection and try there.
Think the wiring is behind the wheel arch liner, you could take that off and hand trace the wiring. It must go through the bodywork at some point to connect to the main wiring, this could be a point where you might find a break in the wire. I installed a towbar recently and I'm sure I seen the wiring for it when I had the liner off.
The sweeping dials are normally a sign that the battery is a bit low. I get it occasionally if the cars been sat for a couple of days or it's been used for a lot of short runs.
Edited by soupstone
