I recently had my 2.8CRD returned from a garage following timing belt change and rear crank seal replacement.
Now, the car is not charging it's battery. Garage said alternator is goosed, but i want to make sure. I've tested continuity between alternator and B+, alternator to B- and it's all ok. I've measured battery voltage on one side of the excitor coil connector, and 300mV (on multimeter) on the other side with the engine running. All i see is battery voltage on the alternator. Any other tests i can do?
Niloc
8 answers to this question
