Got Codes P1685 P1651 P0620 And P0100 Using Key
hotrod1958
P1685 SKIM SYSTEM INVALID SECRET KEY IN EEPROM
P1685 SKIM SYSTEM WRITE ACCESS TO EEPROM FAILURE
P0100 MASS AIR FLOW SENSOR
P 0620 GENERATOR BATTERY FLOW
These are the codes, What are the syptoms? Try the battery disconnect. QuintQ wrote this "SKIM is your immobiliser or Smart Key Immobilizer Module, the code is in the BCM."
