Hi, the third brake light stopped working about 1yr ago and I finally got round to buying a replacement. The bad news is that that hasn't solved the problem and it still doesn't work. In the interim the offside brake light has stopped working however I believe it is the same bulb as the tail light which is working fine. Any suggestions as to what might be causing it or what I could look at trying? The MOT is due next month and I will need to get it sorted by then! Thanks
renfrew999
