Hi. Ok here is the problem. My beloved voyager has been off the road for over a year. I have tried everything I can find online. All started with the engine kept cutting out. The only clue is that when the key is turned one notch, the lift pump keep wirling away - and doesn't stop. I have tried - new lift pump, tank removed and cleaned, clear pipes to see no air getting in, swapped the relay. From what I remember when it was ok, after turning the key it stopped priming after 10 or 20 seconds, could someone clarify this? Question is what sets the duration of the lift pump? There doesn't seem to be any pressure sensor in the pump, how does the ecu know when to stop the pump? I really need help. Any possible ideas or other things to try would really help. My only other thought was, does the prop valve have any part in the system? It still runs, but then cuts out, the ecu must be sensing the problem?
GaryCRD
14 answers to this question
