Hi, would appreciate any advice. My 55 plate Grand Voyager has a problem with the Indicators. About a month ago the indicators stopped working for approx a day, then magically started working again. They've now stopped working completely.
I'm guessing it's either an issue with the Indicator stalk on the steering column or the relay. The hazard warning lights work without any issue. I checked the car manual, it gives lots of info regarding the relays in the IPM Unit next to the battery but none of them appear to be the Indicator relay.
So -
Do the Indicators and the hazard lights share the same relay? (In which case as the hazads work it's possibly the indicator stalk which sounds tricky/expensive).
If they have a separate relay, where's the indicator relay and any hints/tips on changing it please?
RobW
So -
Any other advice for determining the problem?
