No Dash Instruments Working
Shanless
Who reprogrammed your 2 replacement BCM with your VIN and security codes when you fitted them ? If you live near the north east of England I'll give you a free read + clear of your BCM [and other] errors. My advice is stop ..... you have spent endless money going nowhere. Chrysler introduced transponder based anti-theft all the way back in the middle 80's then again in 2004 along with CAN-BUS systems. Your car BCM Issues a challenge & response and your FOB then issues a corresponding VIN ID pin code and the car starts & runs - change the BCM without reprogramming and the car thinks its being stolen.
QinteQ...thanks for your reply
I tried two BCMS with same code..the guy I got the from said that they wouldn't need programmed...he let me try them to see if it fixed the problem....thank you the offer of reading the BCM..but i live in North. Ireland
Thanks.
Edited by Shanless
Hi. I thought that the dash instruments wernt working on my 2001 voyager. Turned out to be as simple as the thin red wire that also attaches to the positive battery terminal wasn't clean. This wire powers many things like electric mirrors. There is also a fuse that runs the basic electrics like dash.
