rancethebus Posted January 2, 2017 Report Share Posted January 2, 2017 Hi everyone,I'm new to the forum having bought a Delta a month ago. The car was a cat D with only minor damage to offside front wing and headlight. Headlight has been replaced but I am still trying to source a wing. It doesn't take much to make a Delta into a Cat D. However when I switch on the ignition, the dashboard, lights up like a Christmas tree. I have warning lights for ABS, EBD, Steering assist, Hill holder and Start/Stop. The lights go through the warnings twice before settling to the warning triangle. However everything works correctly and safely. The car drives perfectly. I am told by a Fiat dealer after it was put on their diagnostics system that the car needs a new rear wheel sensor which will cure the problem. However the previous owner said that the car had already had a new sensor fitted. Has anybody had the same problem? Quote Link to comment Share on other sites More sharing options...
