ametcalfe1989 Posted December 14, 2016 Report Share Posted December 14, 2016 Sometimes, I haven't noticed a trend yet, the hazards flash 2 or 3 times when I start the car.Anybody else experience this and know if it's an issue? Or just typical American wiring? Quote Link to comment Share on other sites More sharing options...
0 gordy Posted December 14, 2016 Report Share Posted December 14, 2016 Maybe a battery issue, is yours quit new. Quote Link to comment Share on other sites More sharing options...
0 ametcalfe1989 Posted December 15, 2016 Author Report Share Posted December 15, 2016 I'm unsure about the battery because I only bought the car recently but it is always worth getting a new one. Thanks, I'll give it a try Quote Link to comment Share on other sites More sharing options...
0 andyb2000 Posted December 16, 2016 Report Share Posted December 16, 2016 I think battery would be a good place to look, do you get 'dash sweep' when you first turn the ignition on too? If you have a multimeter check what voltage the battery reads without anything on, then turn on the lights and blowers (high loads) and see what voltage you see.A good battery shouldn't vary too much under high loads, but a battery that is on it's way out will start to drop voltage quickly. The 2-3 flashes of indicators to me sounds like immobiliser triggered though, as that's the normal de-activate flash they give. When you get in (before key in) is the red LED on the dashboard lit up/flashing? (If yours has it, it's behind the steering wheel sticking through the plastic, so it's a very obvious red LED). Normally this only lights up after I've done work on mine and had the battery disconnected. At first ignition back on it flashes the lights and the LED goes off, so 'disabling' the immobiliser and recognising things are happy again.Low voltage may be causing this to trigger repeatedly. Give the voltage tests a go and see how you get on before buying a new battery, remember there are lots of posts about batteries on here and the .com forum, they are a common weak point especially if you don't buy the right one! Quote Link to comment Share on other sites More sharing options...
ametcalfe1989
