Have had a problem the metal plates, inboard of the front brake discs. One of them rusted away around the 3 bolts holding it onto the axle hub and it was replaced by my local garage. Now the 2nd one has done the same but today, when I went to remove the front wheel to see if I could secure the plate until I have to go to the garage, the McGard wheel nut tool sheared off the fancy patterned part that sits in the groove! It was a lot bit tighter than the usual wheel nuts. So now, I can't remove any of my wheels and I will have to drive around with this loose plate knocking on my front brake disc. I hope the Chrysler garage mechanics will be able to remove the wheel
Edited by gr2bfc
gr2bfc
