No Power To Sliding Doors But Power To Boot
Craig
Hi Craig,
Interesting that it's both doors. If you use the remote/fob is it the same story? Also do you have the power tailgate/boot lift, does that work?
From memory they are on a separate fuse, the fusebox lid is labelled so you should be able to find your way around it and check them. Also an obvious one, check the overhead ON/OFF switch for them as they can be disabled by swapping into the OFF position.
One last check, if you don't close the door properly, does the motor then pull the door in and clunk/click it into place?
I'd be surprised if both door chain feeds have gone, but it's not impossible. It's a common problem, the track you can see in the gap at the base of the floor has a plastic chain, inside that are the power/electrical control wires to the motors and they often will break over time and cause a total failure similar to what you're seeing.
Ah ok, in that case it's a little better! (Not a total failure)
By the sounds of it, it's the movement motor that's failed and that is the common one inside the chain underneath the floor. Do a couple of searches on the forum and you'll find various notes and info on fixing it, but it should be simply a broken wire inside that plastic chain, which you can re-connect together and get it working again.
