Sebring Window
Richstead
Hi Richstead, sorry for the delay and welcome to the forum  :)
As your module is a soft top it would seem that the module (that controls the window up/down) needs reset or possibly replaced. There could of course be a physical obstruction. I would start with trying to relearn the window height (low and high) simply by (door closed) and lowering window whilst keeping down button pressed for a further 10 seconds after it gets to the bottom. The press button up and hold for further 10 seconds when window is at the top.
Try this first (the easy no cost stuff) and let us know the result. If the glass wont go all the way up but stops and comes back down then its likely a obstruction, check for seal damage.
