Steering Vibrating/shaking Violently At Low Speeds
darkchild101
The steering on my 2001 2.5 diesel vibrates/shakes so much you can see my hands moving along with it. Strangely enough the problemis at its worst at low speeds and the faster I go the handling improves. The car shakes or should I say wobbles when negotiating corners or bends. Its far worse than the vibration you get with wheel balance problem. Feels like the wheels are about to come off
Help please
Vibrate not wobble sounds like your ABS / EBD was cutting in a self check occurs each time the vehicle is started and accelerated past approximately 15 mph - so do you get an ABS light warning http://www.youfixcars.com/images/ford-abs-light.jpg ?. Wobble would be warped disks, worn bushes, even tyre pressures, and a tyre 'bleb'.
