Amigaman Posted September 5, 2016 Report Share Posted September 5, 2016 Hi everyone I have just bought myself a Sebring Convertible 2,0 Diesel and I knew I needed a new battery - however there seems to be such confusion over what type of battery I need. The AA man says it needs to be a "Gel" battery - A Chrysler Parts guy says it needs to be a "Spiral Wound" and he also asked if my car had "Stop and Start" technology - Frankly I have no idea - please help Quote Link to comment Share on other sites More sharing options...
Penguin2007 Posted September 6, 2016 Report Share Posted September 6, 2016 Hi Amigoman You pays the cash you gets the product..... Gel batteries have their uses .... £+Sealed cells - mid rangeSpiral ones are £+ See: .... http://www.multicell.co.uk/cyclon-batteries.html(Other suppliers are available). I had to replace my (2 year old from new) low maintenance battery with a new one when the service prior to the MoT, came up as it was failing.I replaced with similar, over rated LM cell, from a decent supplier. I suspect that they are all made by the same unit shifters in the middle east. Would recommend that you go over in the Ah rating - as diesels are a little heavier on the demand in start up process. Technology changes all the time, but make sure that you check with the manual for ratings etc. Hope this helps Penguin Quote Link to comment Share on other sites More sharing options...
