Noise After Stopping
3ddesign
Hi, I've bought my first GV as highly recommended. I started this morning after it being on a charge all night, and after stopping and removing the key there was a noise for a few minutes from the underside of the car. Not sure specifically where. Some white smoke from the drivers side roughly beneath the side door. Any ideas ? Thanks, Mark.
3ddesign,
all automated, comes on automatically when its cold[er], switches off automatically when its water is warm enough. It has a diesel in line from your tank, an automated electrical supply on & off line and a small exhaust out. It will not switch on if you are under a 1/4 tank full.The probable reason it came on in the warm weather would be that (1) it was cold in your area (2) when the battery is connected for a long time all functions run a 'self test'.
