1949mick Posted August 19, 2016 Report Share Posted August 19, 2016 Hi There. Another Newbie picking your collective knowledge. I have a problem with my 2008 Grand Voyager 2.7 CRD. 70,000 miles. The Airbag Light has just illuminated & will not extinguish. Can anyone let me know any checks I can make or fixes before I have to get it to a Garage ?Thanks in anticipation1949mick Quote Link to comment Share on other sites More sharing options...
tomada3 Posted August 19, 2016 Report Share Posted August 19, 2016 hi disconnect battery for couple minutes reconnect if fault still shows then you have fault i got 53 reg v6 had same problem then it just disappered have heard of wires under drivers seat having problems you have some connecters disconnect then reconnect also could be your clock spring ( in steering wheel )if your cruise control dont work or horn it could be thatcheck forum for your car loads answers on there hopes this helps Quote Link to comment Share on other sites More sharing options...
Barny Posted October 3, 2016 Report Share Posted October 3, 2016 My problem is very similar but the drivers SRS bag needing £466.00 to test and replace. any ideas???? Quote Link to comment Share on other sites More sharing options...
