Karld77 Posted August 11, 2016 Report Share Posted August 11, 2016 Does any body know the location of the fuse box as I know there is one under the bonnet but there is some fuses I the Jack compartment . As my reverse lights and fog lights aren't working but bulbs are ok thanks peeps Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted August 16, 2016 Report Share Posted August 16, 2016 Hi, I have the same problem with my rear lights! Sidelights working, indicators working, reverse lights working, but no brake lights! Any ideas guys? Cheers! Quote Link to comment Share on other sites More sharing options...
0 bignev Posted August 16, 2016 Report Share Posted August 16, 2016 (edited) Hi guys!I only know the one under the bonnet, they have several ecu's but not sure about multiple fuse locations. Mine certainly has nothing near the jack, but the rear door ecu is up behind the panel on that side. For the brake lights, try the brake light switch on the brake pedal. Edited August 16, 2016 by bignev Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted August 17, 2016 Report Share Posted August 17, 2016 (edited) Cheers Nev, I've heard about this switch, but can't see it! Obviously I've looked by the pedal but I can't seem to find it! Where am I looking? Do they have problems with the switch? Cheers in advance! Edited August 17, 2016 by robbie2red Quote Link to comment Share on other sites More sharing options...
0 bignev Posted August 18, 2016 Report Share Posted August 18, 2016 (edited) It will be at the top of the pedal, high up, hidden behind the the plastics,when the pedal is pressed the top part of it above the pivot point moves away and breaks the switch contact, lighting up the bulbs. Edited August 18, 2016 by bignev Quote Link to comment Share on other sites More sharing options...
0 robbie2red Posted August 19, 2016 Report Share Posted August 19, 2016 Oh brill, cheers Big Nev for the help! Will take a look again! Thank you! Quote Link to comment Share on other sites More sharing options...
0 bignev Posted August 19, 2016 Report Share Posted August 19, 2016 mmm, sorry - actually technically it makes the contact, it is a plunger that moves out when the part of the pedal moves away from it.Won't make any diference to finding it but I thought I should correct myself!! Quote Link to comment Share on other sites More sharing options...
Karld77
